Moved: Reply To: VisualGDB support
Sysprogs forums Forums VisualGDB Moved: Reply To: VisualGDB support
  • #7296
    TybiBeaton
    Can you please share all the specifications of the VisualGDB?
    What are its components and what it requires to start working with it?
    How it could be interfaced with the Beagleboard?
    Also what type of control i can make with it?
    #7299
    You can use VisualGDB to develop C/C++ applications for Beaglebone. VisualGDB uses SSH to build and debug your code.
    You can build it either directly on the Beaglebone or by using a cross-compiler provided by us. We recommend starting by following our BeagleBone tutorial.
    You can make any application type that is based on C/C++, e.g. Qt-based ones.
