Mounting window appears them innediately disappears
Sysprogs forums › Forums › WinCDEmu › Mounting window appears them innediately disappears
  • #319
    Hello there, giving the latest 3.6 a try for editing Linux ISOs. Installation goes fine but when I try to open an ISO I get the mounting window appear for a split second (just long enough for the Aero animation of the window appearing to happen) then disappears and I end up with nothing. If I try again nothing happens at all, if I leave it a short while I get the same split-second window.
    System is Vista Home Premium 32 bit, it’s also quite crufty (4 years since last re-install and I can be a terrible magpie with software) so my suspicion is some sort of conflict with some other software. Took a look in the event viewer and can’t see anything at all.
    Any other information that might be helpful feel free to ask.
    #1876
    VGA
    You mean you select the mount option from the context menu of an iso and it crashes when it tries to show the window ? Maybe it’s crashing while trying to populate the drive letter list.
    Does the WinCDEmu settings window show up fine ? (From the start menu options)
    #1877
    Thanks for the response, no, trying to open the options does nothing, not even a flicker of a window like with the mounting.
    #1878
    VGA
    Weird, maybe it crashes while enumerating the drives (to find the available letters)
    Open a command prompt as admin and run this command :
    wmic logicaldisk get name
    #1879
    Name:
    A:
    C:
    D:
    E:
    N:
    I can account for all of those, A, C, and D are what you would expect. E is my phone (plugged in at time of command) and N is a NAS I mapped for programs that don’t accept UNC.
