Missing Hardware Registers STM32F446RE
Sysprogs forums › Forums › VisualGDB › Missing Hardware Registers STM32F446RE
  • #9622
    RaEyE
    today I tried to compile and debug a STM32F446RE mBed project, so far so good.
    Only thing I’m missing are Hardware-Registers. I tried to follow your online instroctions on how to enable registers for custom projects (http://visualgdb.com/documentation/hwregs), but found that the menu “Embedded Project” doesn’t represent the option to define a “peripheral register definition file”.
    I configured a STM32F446RE project following your project wizard and selected the STM32F446RE-Nucleo profile for ARM mBed projects. Therefore I would like to know, if it is possible to define the location of said definition file after creating the project, but e.g. editing a xml/ini File where Project-Settings are saved manualy.
    Greetings,
    RaEyE
    #9626
    Sorry about that, this is a bug of the new mbed BSP that is in the Beta stage.
    To fix this, please copy the  %LOCALAPPDATA%\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32\STM32F4xxxx\DeviceDefinitions\stm32f446xx.xml.gz file to %LOCALAPPDATA%\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.mbed\DeviceDefinitions\stm32f446xx.xml.gz and add the following line to the mbed.xml file in your project directory under the EmbeddedProfile element:
      <MCUDefinitionFile>DeviceDefinitions/stm32f446xx.xml</MCUDefinitionFile>
    This will automatically pick the register definitions from the normal STM32 package.
    #9631
    RaEyE
    Thank you ver much for your fast reply.
    Your soulution worked out pretty well and did exactly whit it intended to do.
    Will this be fixed in one of the upcoming releases?
    #9643
    Yes, we will fix this in the final BSP release.
