@yudiannlu wrote:
I had try rebuild “allModules”, but “bszlib” folder and “allmodules” folder – cause some compiling error. Could you share you Directory structure idea?
I haven’t used allmodules, but compiled only part by part
This worked for me
1. Install DDK (Not the windows8 one, you need one version older)
2. Install BazisLib using installer and go through wizard (it will ask for DDK path)
3. After opening project in wincdemu, fix bazislib project path (if you have bazislib under c:bazislib, it should pic it up without problem) by removeing and readding project in solution, or you can edit project file in some text editor
4. Fix includes path in projects properties (you need to add bazislib into include path)
5. It should compile now without problem, if you encounter problem with autorundisabler i had, you need to recompile autorundisabler alone first (to get some headers generated)
