MBED susbsystem – can't add/change target platform
Sysprogs forums Forums VisualGDB MBED susbsystem – can't add/change target platform
Viewing 14 posts - 1 through 14 (of 14 total)
  • #22728
    maras
    On blog: https://sysprogs.com/w/introducing-advanced-mbed-project-subsystem/ i found information about possibility od add/change target platform of my project and retargetting project to different versions of mbed framework.
    Unfortunately I can’t find this features and I do not know if they are present at all ?
    • This topic was modified 7 years, 10 months ago by maras.
    #22732
    Please try right-clicking on the project in Solution Explorer and select Add->Manage Mbed Platforms.
    #22733
    maras
    OK, I found mbed platfom managing, but where is retargetting project to different versions of mbed framework feature ?
    #22734
    maras
    Changing target from NUCLEO_F429ZI to NUCLEO_F072RB ended with error:
    Building project N429ZICayenneWIFI (NUCLEO_F072RB, GCC_ARM)
     Scan: N429ZICayenneWIFI
     Compile [ 0.1%]: CayenneUtils.c
     Saved the code model to C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\VisualGDBCache\N429ZICayenneWIFI-Debug-NUCLEO_F072RB\BuildCommandLines.txt
     System.ArgumentException: Illegal characters in path.
     at System.IO.Path.CheckInvalidPathChars(String path, Boolean checkAdditional)
     at System.IO.Path.IsPathRooted(String path)
     at l81..ctor(w71 a, String b)
     at ve.f(d a, List`1 c, w71 b)
     at ve.l(d b, vc1 c, w71 a)
     at j52.a(String a, IEnumerable`1 b)
     at e52.a.j_2(IEnumerable`1 a)
     at a62.b_2()
     at ew1.e()
    • This reply was modified 7 years, 10 months ago by maras.
    • This reply was modified 7 years, 10 months ago by support. Reason: formatting
    #22737
    You can find the retarget command by right-clicking on the mbed-os library in Solution Explorer.
    The build error looks like some of the paths in your project settings might be incorrect. Please let us know the VisualGDB build number you are using (from the About window) that corresponds to the stack trace above and share the diagnostic output from View->Other Windows->VisualGDB Diagnostic Output that is generated when you try to open the project.
    #22740
    maras
    Visual GDB 5.4 preview 9 build 2571
    Output:
    Loading cached code model from C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\VisualGDBCache\N429ZICayenneWIFI-Debug-NUCLEO_F072RB\BuildCommandLines.txt...
    Failed to parse code model from cached file: System.ArgumentException: Illegal characters in path.
    at ve.f(d a, List
    1 c, w71 b)
    at j52.a(String a, IEnumerable1 b)
    at e52.a.j_2(IEnumerable1 a)
    at a62.b_2()
    Checking if any source files need uploading...
    [mbed] Auto-installing missing Python modules...
    [Warning] C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI::: Compiler version mismatch: Could not detect version; expected version >= 6.0.0 and < 7.0.0
    Compile [ 0.1%]: CayenneDataArray.c
    Compile [ 0.3%]: CayenneUtils.c
    Compile [ 0.4%]: MQTTConnectClient.c
    Compile [ 0.5%]: MQTTDeserializePublish.c
    Compile [ 0.7%]: MQTTPacket.c
    Compile [ 0.8%]: MQTTSerializePublish.c
    Compile [ 0.9%]: MQTTSubscribeClient.c
    Compile [ 1.1%]: MQTTUnsubscribeClient.c
    Compile [ 1.2%]: DS1820.cpp
    Compile [ 1.3%]: OneWire.cpp
    Compile [ 1.5%]: bme280.cpp
    Compile [ 1.6%]: msARM_BME280_I2Cdriver.cpp
    Compile [ 1.8%]: mbed_tz_context.c
    Compile [ 1.9%]: NanostackRfPhyAtmel.cpp
    Compile [ 2.0%]: MCR20Drv.c
    Compile [ 2.2%]: NanostackRfPhyMcr20a.cpp
    Compile [ 2.3%]: NanostackRfPhys2lp.cpp
    Compile [ 2.4%]: rf_configuration.c
    Compile [ 2.6%]: ESP8266Interface.cpp
    Compile [ 2.7%]: AnalogIn.cpp
    Compile [ 2.8%]: BusIn.cpp
    Compile [ 3.0%]: BusInOut.cpp
    Compile [ 3.1%]: BusOut.cpp
    Compile [ 3.2%]: CAN.cpp
    Compile [ 3.4%]: FlashIAP.cpp
    Compile [ 3.5%]: I2CSlave.cpp
    Compile [ 3.6%]: I2C.cpp
    Compile [ 3.8%]: InterruptIn.cpp
    Compile [ 3.9%]: InterruptManager.cpp
    Compile [ 4.0%]: frammemory.cpp
    at ve.f(d a, List1 c, w71 b)
    at a62.b_2()
    at ew1.e()
    Diagnostic output:
    RenameHighlightSmartTaggerProvider: creating tagger for C/C++...
    RenameHighlightSmartTaggerProvider: creating tagger for C/C++ (VisualGDB)...
    RenameHighlightSmartTaggerProvider: created tagger for C/C++ (VisualGDB)...
    SysprogsSuggestedActionsProvider: creating tagger for C/C++ (VisualGDB)...
    SysprogsSuggestedActionsProvider: Creating a SuggestedActionsSource for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\lib\Cayenne\Platform\mbed\MQTTNetwork.h...
    Creating a SuggestedActionsProvider for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\lib\Cayenne\Platform\mbed\MQTTNetwork.h...
    No backend client found. Could not create the SuggestedActionsProvider
    SysprogsSuggestedActionsProvider: Creating a SuggestedActionsSource for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\src\main.cpp...
    Creating a SuggestedActionsProvider for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\src\main.cpp...
    SysprogsSuggestedActionsProvider: Creating a SuggestedActionsSource for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\lib\FRAM\frammemory.cpp...
    Creating a SuggestedActionsProvider for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\lib\FRAM\frammemory.cpp...
    SysprogsSuggestedActionsProvider: Creating a SuggestedActionsSource for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\lib\FRAM\frammemory.h...
    Creating a SuggestedActionsProvider for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\lib\FRAM\frammemory.h...
    SysprogsSuggestedActionsProvider: Creating a SuggestedActionsSource for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\mbed-os\components\wifi\esp8266-driver\ESP8266Interface.cpp...
    Creating a SuggestedActionsProvider for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\mbed-os\components\wifi\esp8266-driver\ESP8266Interface.cpp...
    SysprogsSuggestedActionsProvider: Creating a SuggestedActionsSource for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\mbed-os\components\wifi\esp8266-driver\ESP8266Interface.h...
    Creating a SuggestedActionsProvider for C:\Users\mares\source\repos\N429ZICayenneWIFI\N429ZICayenneWIFI\mbed-os\components\wifi\esp8266-driver\ESP8266Interface.h...
    #22744
    maras
    I tried now change platform from basic NUCLEO F429ZI to NUCLEO L433RC_P and all works good.
    I think the problem is only for some targets.
    #22748
    maras
    Creating new Bliky project for NUCLEO_F072RB platform generates the same error.
    Compile [ 99.5%]: sleep.c
    Compile [ 99.6%]: stm_spi_api.c
    Compile [ 99.7%]: us_ticker.c
    Compile [ 99.9%]: pwmout_api.c
    Saved the code model to C:\Users\mares\source\repos\N072test\N072test\VisualGDBCache\N072test-Debug-NUCLEO_F072RB\BuildCommandLines.txt
       at ve.f(d a, List 1 c, w71 b)
       at j52.a(String a, IEnumerable 1 b)
       at e52.a.j_2(IEnumerable 1 a)
       at a62.b_2()
       at ew1.e()
    #22750
    maras
    Can’t create new Blinky project for any of my platforms NUCLEO_F429ZI, F072RB or L433RC_P
    #22771
    Sorry about that and thanks for sharing the 100% repro steps. Looks like VisualGDB was not unescaping some arguments properly. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.10.2583.msi
    #22773
    maras
    Looks good, I can create new project, I can change terget board, but I have about 80 Intellisense Errors, altough project builds without errors.
    Severity	Code	Description	Project	File	Line	Suppression State
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\targets\TARGET_STM\TARGET_STM32F0\TARGET_NUCLEO_F072RB\device\stm32f072xb.h	134
    Error		[Clang IntelliSense] Error: 'algorithm' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\drivers\FlashIAP.h	31
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\drivers\TableCRC.h	20
    Error		[Clang IntelliSense] Error: 'stddef.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\events\equeue\equeue.h	31
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\events\equeue\equeue.h	32
    Error		[Clang IntelliSense] Error: 'stdbool.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\events\equeue\equeue_platform.h	28
    Error		[Clang IntelliSense] Error: 'cstddef' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\events\EventQueue.h	23
    Error		[Clang IntelliSense] Error: 'new' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\events\EventQueue.h	24
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\features\netsocket\nsapi_types.h	23
    Error		[Clang IntelliSense] Error: 'string.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\features\netsocket\WiFiAccessPoint.h	20
    Error		[Clang IntelliSense] Error: 'string.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\features\netsocket\WiFiInterface.h	21
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\features\storage\blockdevice\BlockDevice.h	20
    Error		[Clang IntelliSense] Error: 'stdlib.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\features\storage\blockdevice\ChainingBlockDevice.h	27
    Error		[Clang IntelliSense] Error: 'string.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\features\storage\blockdevice\HeapBlockDevice.h	27
    Error		[Clang IntelliSense] Error: 'stdlib.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\features\storage\blockdevice\HeapBlockDevice.h	28
    Error		[Clang IntelliSense] Error: 'stddef.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\buffer.h	22
    Error		[Clang IntelliSense] Error: 'stdbool.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\crc_api.h	21
    Error		[Clang IntelliSense] Error: 'stddef.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\crc_api.h	22
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\crc_api.h	23
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\dma_api.h	22
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\flash_api.h	23
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\gpio_api.h	22
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\ticker_api.h	22
    Error		[Clang IntelliSense] Error: 'stdbool.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\ticker_api.h	23
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\hal\us_ticker_api.h	22
    Error		[Clang IntelliSense] Error: 'math.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\mbed.h	43
    Error		[Clang IntelliSense] Error: 'time.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\mbed.h	44
    Error		[Clang IntelliSense] Error: 'cstdarg' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\ATCmdParser.h	24
    Error		[Clang IntelliSense] Error: 'string.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\Callback.h	19
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\Callback.h	20
    Error		[Clang IntelliSense] Error: 'new' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\Callback.h	21
    Error		[Clang IntelliSense] Error: 'limits.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\DeepSleepLock.h	19
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\DirHandle.h	19
    Error		[Clang IntelliSense] Error: 'cstdio' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\FileHandle.h	21
    Error		[Clang IntelliSense] Error: 'string.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\FunctionPointer.h	21
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\FunctionPointer.h	22
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_application.h	20
    Error		[Clang IntelliSense] Error: 'stdbool.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_critical.h	22
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_critical.h	23
    Error		[Clang IntelliSense] Error: 'stddef.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_critical.h	24
    Error		[Clang IntelliSense] Error: 'stdio.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_debug.h	27
    Error		[Clang IntelliSense] Error: 'stdarg.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_debug.h	28
    Error		[Clang IntelliSense] Error: 'stdarg.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_interface.h	27
    Error		[Clang IntelliSense] Error: 'stdbool.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_power_mgmt.h	29
    Error		[Clang IntelliSense] Error: 'cstdio' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_retarget.h	23
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_retarget.h	27
    Error		[Clang IntelliSense] Error: 'stddef.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_retarget.h	28
    Error		[Clang IntelliSense] Error: 'errno.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_retarget.h	36
    Error		[Clang IntelliSense] Error: 'time.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_retarget.h	79
    Error		[Clang IntelliSense] Error: 'time.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_rtc_time.h	24
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_stats.h	25
    Error		[Clang IntelliSense] Error: 'stddef.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\mbed_stats.h	26
    Error		[Clang IntelliSense] Error: 'cstddef' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\platform.h	22
    Error		[Clang IntelliSense] Error: 'cstdlib' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\platform.h	23
    Error		[Clang IntelliSense] Error: 'cstdio' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\platform.h	24
    Error		[Clang IntelliSense] Error: 'cstring' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\platform.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\SingletonPtr.h	26
    Error		[Clang IntelliSense] Error: 'new' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\SingletonPtr.h	27
    Error		[Clang IntelliSense] Error: 'cstdio' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\Stream.h	23
    Error		[Clang IntelliSense] Error: 'cstdarg' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\platform\Stream.h	24
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\ConditionVariable.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\EventFlags.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\Kernel.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\Mail.h	25
    Error		[Clang IntelliSense] Error: 'string.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\Mail.h	26
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\MemoryPool.h	25
    Error		[Clang IntelliSense] Error: 'string.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\MemoryPool.h	26
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\Mutex.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\RtosTimer.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\Semaphore.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\TARGET_CORTEX\rtx5\Include\cmsis_os2.h	64
    Error		[Clang IntelliSense] Error: 'stddef.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\TARGET_CORTEX\rtx5\Include\cmsis_os2.h	65
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\TARGET_CORTEX\rtx5\RTX\Include\rtx_os.h	29
    Error		[Clang IntelliSense] Error: 'stddef.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\TARGET_CORTEX\rtx5\RTX\Include\rtx_os.h	30
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\ThisThread.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\rtos\Thread.h	25
    Error		[Clang IntelliSense] Error: 'stdint.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\targets\TARGET_STM\mbed_rtx.h	20
    Error		[Clang IntelliSense] Error: 'stdio.h' file not found		C:\Users\maras.DAMIR\source\repos\MbedProject8\MbedProject8\mbed-os\targets\TARGET_STM\TARGET_STM32F0\device\stm32f0xx_hal_def.h	50
    #22788
    Thanks for pointing this out – it turned out to be a bug introduced by the recently added Keil/RTX integration.
    Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.10.2587.msi
    #22801
    maras
    Looks good.
    How to force refreshing of project structure without erasing VisualGDBCache folder ?
    #22802
    Yes, please try right-clicking on the project in Solution Explorer and select “Reload Project”.
