May I ask Visualgdb when debugging the result output to the debugging window? De
Sysprogs forums Forums VisualGDB May I ask Visualgdb when debugging the result output to the debugging window? De
  • #12787
    Yuex.S
    May I ask Visualgdb when debugging the result output to the debugging window? Debug output similar to Visual Studio
    #12794
    Normally the output from the ESP8266/ESP32 programs is directed to a serial port, so in order to see it you would need to use the raw terminal feature (requires the Custom edition or higher). If you are using a lower edition, please try using our free SmarTTY tool instead to view the output from the COM port.
    #12795
    Yuex.S
    Can I upgrade?
    #12796
    Yuex.S
    It was nice to see Smartty, thank you.
    #12798
    Good to know it works. BTW, if you miss any other features of the Custom edition, you can always upgrade here: http://sysprogs.com/splm/mykey.
