i’m experiencing problems with the following line generated by VisualGDB on Visual Studio 2013 on a Qt5 project.
I’d like to note that we’re evaluating your product for buying some licenses.
$(TARGET): Debugui_MainWindow.h $(OBJECTS)
@test -d Debug || mkdir -p Debug
$(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJCOMP) $(LIBS)
I’m already checked that the make.exe version and test.exe version are those shipped in your beaglebone toolchain.
There’re more that one problem with the line:
First:
mkdir does not support -p. Infact if i esecute mkdir -p Debug a directory with name “-p” is created
Second:
The make program exit on that line because a space is missing after “mkdir -p Debug”.
Infact if i i change the makefile to “mkdir -p Debug ” (<-- note that there's a space after the trailing )
The compilation goes on perfectly.
I don’t know who generate that makefile if visualgdb or qmake. However visualgdb rewrite that makefile
each time i hit the build program. So i’m stucked.
