Makefile filename gets changed and make fails
Sysprogs forums › Forums › VisualGDB › Makefile filename gets changed and make fails
  • #10521
    hindus
    Hi, I’ve developed my Raspberry Pi  C++ application for a while and everything was working all right. I moved to other project and returned yesterday, after few months.
    At first I got some build errors.
    1>  make: *** No rule to make target 'Debug/DEVICE~1.CPP', needed by 'Debug/DeviceController'.  Stop.
    Solution clean didn’t do the trick so I double check project properties. Everything was ok. What is more, 1 out of 3 projects in my previously working solution was building ok.
    I reverted everything with git to the point I knew it was working, together with project and configuration files. Again, it failed with error.
    Then I realised that there is this DOS-compatible 8-char file name in my makefile, and it was the only change that appeared (according to git) after I clicked Local Windows Debugger in my Visual Studio. Somehow running the build changed:
    SOURCEFILES := DeviceController.cpp ZoneTime.cpp
    to
    SOURCEFILES := DEVICE~1.CPP ZoneTime.cpp
    And this caused make to fail. I fixed the name, run build again and the name changed, causing make to fail. I tried one more thing and run make from the cmd, using paths from Output window. Everything went smooth and make finished with no errors. I ran it from Visual Studio = error. I ran it with cmd again – error. So clearly there is something that causes that name change. I am 100% sure it was working previously and as you can see, the only problem is that changed name.
    Does anyone know why it’s happening? I could change the name, but why was it working before and now isn’t?
    • This topic was modified 9 years, 7 months ago by hindus.
    #10523
    VisualGDB could do that as a workaround if you project path contains spaces (otherwise Make won’t handle dependencies properly). Please move the project to a path with no spaces.
    #10525
    hindus
    Moving my project folders and solution file to path without spaces resolved my issue. Thanks!
