Linking Symbolic Link Paths to Windows Directory
Sysprogs forums Forums VisualGDB Linking Symbolic Link Paths to Windows Directory
  • #6767
    dmitryponv
    Good Afternoon,
    I am very close to getting a large cmake project ported over from eclipse, which has been increasingly unreliable, to VisualGDB, which has proven to be more stable and easier to use.
    I have been able to include all of the necessary folders and includes and I copied my entire arm toolchain Xubuntu using “cp -RL”. The -RL option replaces all symbolic links with copies of the file they link to.
    Everything works fine and compiles 100% except that I get underfined references in the linker, when some text files files, like libc.so, specify direct paths, like /usr/lib.
    For example, libc.so is really a text file that has contents:
    OUTPUT_FORMAT(elf32-littlearm)
    GROUP ( /lib/libc.so.6 /usr/lib/libc_nonshared.a  AS_NEEDED ( /lib/ld-linux-armhf.so.3 ) )
    Where the /lib/ and /usr/lib/ paths try to look for files fromt he root directory, and fail.
    If I change it to this:
    GROUP ( libc.so.6 libc_nonshared.a  AS_NEEDED ( ld-linux-armhf.so.3 ) )
    it works, but then I need to edit a lot of the text .so files, and I need to do this every time the toolchain is recompiled, which is very often.
    I understand the Path Mapping feature of VisualGDB is supposed to fix this issue,
    However, I tried adding the following parameters, and this never made any of the errors disappear:
    Additional Source Path Mappings:
    /usr/lib D:\sysroots\cortexa9hf-vfp-neon-poky-linux-gnueabi\usr\lib
    /lib D:\sysroots\cortexa9hf-vfp-neon-poky-linux-gnueabi\lib
    Absolute Paths (starting with ‘/’)
    Relative Paths:
    Tried combinations of GDB Path Styles:
    CygWin [c:\dir\file.cpp]
    CygWin [c:/dir/file.cpp]
    MinGw [c:\dir\file.cpp]
    MinGw [c:/dir/file.cpp]
    Is this correct? What May I be setting wrong?
    • This topic was modified 10 years, 8 months ago by dmitryponv.
    #6773
    VisualGDB path mappings only affect the error messages and paths reported by the debugger; they do not change the inner logic of the toolchain.
    You can use the ‘=’ prefix to specify paths relative to the sysroot, e.g.:
    GROUP ( =/lib/libc.so.6 =/usr/lib/libc_nonshared.a  AS_NEEDED ( =/lib/ld-linux-armhf.so.3 ) )
    If you need to change the files often, the easiest solution would be to make a simple script for adjusting the paths in the newly copied files. It should be doable with a few regular expressions…
    #6785
    dmitryponv
    Ok thank you,
    I fixed it by setting SysRoot directly in the toolchain-Debug.cmake file
    SET(CMAKE_SYSROOT D:/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi)
    #6805
    Yes, that should work. Normally if the toolchain is built correctly, it should pick up the sysroot directory from the standard location automatically. If not, specifying –sysroot=xxx (a.k.a. CMAKE_SYSROOT in Cmake) is the way to go.
