Linking-Error: arm-eabi/bin/ld.exe: cannot find -lBIQ_CM4_GCC
Sysprogs forums › Forums › VisualGDB › Linking-Error: arm-eabi/bin/ld.exe: cannot find -lBIQ_CM4_GCC
  • #25371
    runout
    there is a software package from ST-Micro “STM32CubeExpansion_Audio_V1.1.1”
    with support for Audio-Processing. (Mute/Filter etc.)
    It compiles completely.
    Linking failed!
    The Lib-Properties seems correct.
    1>Linking ../VisualGDB/Debug/Project…
    1>c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-eabi/7.2.0/../../../../arm-eabi/bin/ld.exe: cannot find -lBIQ_CM4_GCC
    What is the Reason for this Link-Error?
    Wrong Version, wrong Lib.
    Compiling/Linking with Keil 5 works.
    Kind Regards
    Thomas
    #25374
    It looks like the project requires the BIQ_CM4_GCC library that could not be located in the standard library search paths.
    Please try locating the library manually (it should normally be shipped together with the project) and add its directory to the Library Directories field in VisualGDB Project Properties.
    You can find out more about library-related settings here: https://visualgdb.com/support/linkerinputs/
    #25380
    runout
    you’ve seen my attachment?
    An Entry in “Additional Linker Inputs” also not works.
    The Raw-Name of the Lib is “BIQ_CM4_GCC.a” (not libBIQ_CM4_GCC.a)
    Maybe a Issue with the name conventions?
    Is there a Visual-GDB-Menu for setup the Linker Options?
    (verbose e.g.)
    Kind regards
    Thomas
    #25381
    runout
    Edit: Problem solved (Name-Convention)
    <lib>LibName<.a> is the required format (at least at Arm-GCC)
    #25383
    Sorry for the confusion. If the physical library name doesn’t include the “lib” prefix, the easiest way to add it to the project would be to simply add it to the Solution Explorer as if it was a source file (Add->Existing Item). This will have the same effect as using the “Additional linker inputs” field, but will make it slightly easier to manage.
