Linker cannot find path
Sysprogs forums Forums VisualGDB Linker cannot find path
  • #35463
    carneytom1981
    I have a strange problem. I am building a unit test project and I am attempting to include some additional source files. When I attempt to build, I get a linker error:
    Linking ../VisualGDB/Debug/Cerus32.UnitTests...
    c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: cannot find C:/Development/Cerus32/Cerus32/Inc: Permission denied
    Build failed: arm-none-eabi-g++.exe exited with code 1
    I know that this path exists.  But when I click on the linked path in the ‘VisualGDB Build’ output, I get the attached error showing a different path which does not exist.  It seems that for some reason VisualGDB is converting the correct path:
    C:\Development\Cerus32\Cerus32\Inc
    into the incorrect path:
    C:\SysGCC\arm-eabi\Development\Cerus32\Cerus32\Inc
    There is nothing in the Path Mapping section of the project properties.
    Could anyone please advise why this is happening and how I can stop it?
    #35469
    It looks like you have specified invalid settings at some point. Unfortunately, it’s impossible to suggest anything meaningful without knowing what exact settings you have used.
    Please try creating a new project from scratch, ensure that it builds, and then try changing one setting at a time until the problem triggers. Once you can reproduce it, please share a screenshot of the exact setting you changed and we will try to suggest a workaround.
