Keil Project Changed Message: Missimg Ask again.
Sysprogs forums Forums VisualGDB Keil Project Changed Message: Missimg Ask again.
  • #27484
    jokn
    Hi Developers,
    <span class=”tlid-translation translation” lang=”en”><span class=”” title=””>I want to get rid of this message.</span> <span title=””>A check box like “Don’t ask me again” is missing.</span></span>
    #27486
    You can remove the link to the original project by removing the ImportedProject element from the embedded profile file (typically called mcu.xml, stm32.xml, etc. in the project directory).
    This will permanently disable this warning.
