JLink Ultra+ Stop Debugging but the processor keeps running
Sysprogs forums Forums VisualGDB JLink Ultra+ Stop Debugging but the processor keeps running
  • #36962
    Kevin
    I have just bought a J-Link Ultra+ and its working correctly and I can flash the boards and debug correctly in Visual Studio 2022 however when I end a debugging session it does not halt the processor similar to the ST-Link I was using previously. Are their any commands I can pass in the settings of Visual GDB in Visual Studio 2022 to halt the processor when debugging ends?
    I was not sure if this was a question for both Visual GDB team or Segger team.
    Many thanks for your time.
    Hope you can help me.
    /Kevin
    #36963
    This is likely caused by a particular combination of settings, and the challenge would be narrowing down the exact settings.
    You can start by logging the J-Link GDB server command line and the GDB commands via VisualGDB (View->Other Windows->VisualGDB Diagnostics Console for command lines and VisualGDB Project Properties -> Advanced GDB Settings to enable GDB logging). This should help you reproduce the problem with just command-line tools from Segger, so you can share the repro steps to them and see if they have any suggestions.
    #36965
    Kevin
    Many thanks I’ve taken a log and I’ve registered on their forum for support I will see what they say regarding it
    Attached is the log for reference.
