Issues debugging
Sysprogs forums › Forums › VisualGDB › Issues debugging
  • #13016
    gworkman
    Hi all,
    This just happened to me today. For context, I didn’t just install updates or change of the configuration files (to my knowledge). I started a new project as an import from STM32 CubeMX, and after writing a few tasks I got the following error:
    No executable file specified.
    Use the “file” or “exec-file” command.
    Cannot resolve the address of _estack. Skipping stack pointer validity check.
    It started running the last built project instead. There were no build errors. The main difference that I noticed from normal was that the flash memory was not reprogrammed before attempting to run it.
    I’m still pretty new to ARM dev, so any help is appreciated. Thanks
    #13018
    Looks like you are trying to debug a project that is not built. Please build it first.
    If it doesn’t help, please attach the entire gdb log as described here and we can help you understand what is going on.
    #13020
    gworkman
    The project was building, and had no build errors. I just found the issue though: earlier I had moved my work space folder to a path that had a space in it. Now that I removed the space, it works as expected. Thank you for the reply and support
    • This reply was modified 8 years, 11 months ago by gworkman.
