Issue with Clang
Sysprogs forums Forums VisualGDB Issue with Clang
Viewing 11 posts - 1 through 11 (of 11 total)
  • #20262
    sidprice
    I have a problem with the drop-down code browsing controls in the main edit windows of VS2017. I noticed that a whole group of functions were not being listed. They all have the same return type of “bool”. If I change the return type to “void” and ignore the warning about the return statement the function then appears in the drop-down.
    The type “bool” is defined as “_Bool”. If I use “_Bool” the drop-down has the function.
    Sid
    • This topic was modified 8 years ago by sidprice.
    #20264
    This could happen if your code contained some definitions that would not be correctly parsed by Clang (normally it would result in errors in the Error pane). Feel free to attach a repro project and we will look into fixing this.
    #20272
    sidprice
    Here you go,
    Sid
    #20273
    sidprice
    Try file again … Sid
    #20282
    Thanks, we have reproduced and fixed the problem. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.1.2077.msi
    #20285
    sidprice
    I downloaded that and it does not fix the issue. Do I need to force a rescan of the CLang data somehow?
    Sid
    #20286
    Any edit to the source file should be sufficient to rebuild the related parts of the cache. If this still doesn’t work, please let us know.
    #20290
    sidprice
    I added a new function to the test project I sent you, it still does not display all the functions in the file,
    Sid
    #20293
    Strange, we have just double-checked that project on a different machine and it still worked. Please double-check the timestamp on the C:\Program Files (x86)\Sysprogs\VisualGDB\CppEngineCore64.dll file – it should be February 26th. If not, please double-check the VisualGDB version under Help->About VisualGDB and try reinstalling the temporary build we mentioned.
    #20299
    sidprice
    I did the download again and installed. It appears to have fixed the issue. However, the version in the About box is not 5.4.1.2077. Snip attached.
    Many thanks,
    Sid
    #20301
    The build number (2077) looks correct, so looks like it got installed properly this time.
