Issue when importing KSDK 2.2 manifest file
Sysprogs forums › Forums › VisualGDB › Issue when importing KSDK 2.2 manifest file
  • #11464
    mattbarn
    Hi, I’m getting an error when I try to import a KSDK 2.2 manifest file.   I can send in the file if that would help.  Thanks!
    VisualGDB version: 5.2.15.1452
    ------------------ System.NullReferenceException ------------------
     at KSDK2xImporter.KSDKManifestParser.ParseKSDKManifest(String sdkDirectory, IWarningSink sink)
     at KSDK2xImporter.KSDKManifestParser.GenerateBSPForSDK(String directory, IWarningSink sink)
     at VisualGDB.GUI.WPF.PackageListDataObject.ExternalImporterWrapper.Run(PackageListDataObject obj)
     at VisualGDB.GUI.WPF.PackageManagerWindow.ImporterButtonClick(Object sender, RoutedEventArgs e)
    #11473
    This is a known issue. It looks like the KSDK manifest format has recently changed. We are working on a fix for it and will release an update in the next few weeks.
    #11474
    mattbarn
    OK, thanks.   I have a somewhat related issue with a KSDK 1.3 project.  If I build a sample project, it works perfectly, but when I include a UART driver and try to init and send a sample string, I get “undefined reference to ‘UART_DRV_Init'” for each function.  I know it can find the code because I can hover over the functions and see the documentation.  Do I need to add each driver source file and all of its dependencies to the solution manually?
    #11477
    Yes, our Kinetis packages are less sophisticated than STM32 and Nordic ones, so the driver .c files need to be added to the project manually. The missing include paths should still be automatically discovered after you open any of the files that tries to include the missing headers.
    #12260
    OK, we have finally updated our KSDK importer to work with the latest v2.1 and v2.2 KSDK releases. You can download a build supporting it here: http://sysprogs.com/files/tmp/VisualGDB-5.3.7.1769.msi
