Is there a way to disable non UTF-8 encoding warning
Sysprogs forums Forums VisualGDB Is there a way to disable non UTF-8 encoding warning
  • #29443
    Gordon01
    Sometimes I need a file to be in 1-byte encoding, for example when I use national symbols with 1-byte fonts.
    The warning “The current file is using an encoding that is not supported by Clang IntelliSence” is a little annoying because it’s bright and cannot be closed.
    Can you please make this warning dismissable?
    #29458
    Thanks for confirming your support status. You can turn off unsupported encoding hints using the “Show Unsupported Encoding Hints” setting under Tools->Options->VisualGDB, as long as you are using the latest VisualGDB 5.5R2. See this page for the exact and up-to-date path of the setting.
