Is #include_next supported in Intellisense path searching?
Sysprogs forums › Forums › VisualGDB › Is #include_next supported in Intellisense path searching?
  • #28200
    Ophidian14
    I have a VisualGDB project set up against a source library that is being built with devtoolset-8, an add-on for CentOS7 that allows you to use upstream compilers (i.e. gcc 8.3) side by side with the system’s installed gcc version (i.e. 4.8).  I then add in the include paths for those system headers into my project (i.e. /opt/rh/devtoolset-8/include/….)
    What I’m seeing is that if I only #include <cstdlib> then any reference to malloc and free in my code shows up as undefined.  If I #include <stdlib.h> directly I don’t have a problem.  When I looked into this further the only thing I could really see is that <cstdlib> is using #include_next, and not #include, to pull in stdlib.h.  Would that be a problem for VisualGDB?  In the attached screenshot the text of the path is showing black, and not amber, as if it is not being understood.
    #28204
    Normally, #include_next<> should work. Please try following our IntelliSense diagnostics tutorial to see the exact options used by VisualGDB’s IntelliSense for the project and for clues why it may not work.
    #28353
    Ophidian14
    Thank you, the problem ended up being my ordering of Intellisense directories.
