Invalid Ruleset Name: ConfigurationGeneral
Sysprogs forums › Forums › VisualGDB › Invalid Ruleset Name: ConfigurationGeneral
  • #32994
    AChomski
    Hi there,
    I’m trying to update an imported Embedded Project using Visual Studio Community 2022 & VisualGDB 5.6 but I keep running into this error:
    VisualGDB version: 5.6.106.4622
    —————— System.ArgumentException ——————
    System.ArgumentException: Invalid ruleset name: ConfigurationGeneral
    at em2.SetCustomPropertyValue(String a, String b, String c)
    at z82.b(IVCConfiguration a, ToolchainKey b)
    at xw.p(ph3 d, IProjectEditContext b, Boolean c, KeilComponentTree a, String[] e)
    at x33.t()
    trace=[em2.SetCustomPropertyValue:41, z82.b:0, xw.p:1430, x33.t:937]
    System.ArgumentException: Invalid ruleset name: Gcc
    at em2.GetCustomPropertyValue(String c, String b, Boolean a)
    at nf.m(IVCConfiguration c, e b, String a)
    at nf.l(IVCConfiguration a)
    at qb2.e(Dictionary`2 c, String f, ph3 e, iu1 b, InvariantProjectBuildSettings d, InvariantProjectBuildSettings a)
    at qb2.j(Dictionary`2 c, String e, ph3 f, ImportedProjectProfile d, ImportedExternalProject a, Boolean b)
    at qb2.f.b_2(r3 b, Object a)
    at x33.f.c_2(r3 a)
    at x33.p.j()
    trace=[em2.GetCustomPropertyValue:42, nf.m:60, nf.l:5, qb2.e:26, qb2.j:206, qb2+f.b_2:271, x33+f.c_2:64, x33+p.j:252]
    I have tried uninstalling VisualGDB & Visual Studio, then reinstalling first Visual Studio w/C++ desktop development then VisualGDB but that doesn’t fix it. Running the VisualGDB installer and selecting repair does not fix it either. Would appreciate any advice on how to fix my installation.
    #32996
    It looks like the MSBuild logic for the project has not been initialized properly. Please double-check whether you can create/edit a new project of the similar type. If yes, please try comparing the failing project file against the newly created project file.
    If the new project doesn’t work either, please let us know and we will help you narrow this down further.
    #35712
    teslasystems
    I have the same problem while creating a new project.
    I’m a beginner to STM32 and VS and was trying to create a simple project just for testing following your tutorial with one exception that STLink v2 was selected as a debugger (https://visualgdb.com/tutorials/arm/stm32/)
    On step 12 after clicking “Finish” button in the wizard the following error appeared:
    VisualGDB version: 6.0.101.5147
    at fu.SetCustomPropertyValue(String c, String b, String a)
    at hi.a(xe2 a, IProjectEditContext b, x g, a42 f, e d, Boolean c, g[] e)
    at lh.n(EmbeddedWizardState a, IProjectEditContext b, rz f, xe2 c, String e, a42 d)
    at lh.DoRunWizardOrThrowException(a42 a, String c, String b)
    at ax1`1.Execute(Object d, IntPtr e, Object[]& c, Object[]& a, wizardResult& b)
    trace=[fu.SetCustomPropertyValue:41, hi.a:404, lh.n:1346, lh.DoRunWizardOrThrowException:652, ax1`1.Execute:210]
    Can you explain, what this error means and what should be done to resolve it?
    #35713
