Invalid Boot.ini file Error
Sysprogs forums Forums VisualDDK/VirtualKD discussion Invalid Boot.ini file Error
  • #511
    khalid Ishaque
    Hello
    I am using Windows XP SP3 as Host and the same (XP) on virtualbox. I am using VisualDDK and Visual studio 2008. I rename VBoxDD.dll to VBoxDD0.dll and copy VBoxDD.dll from visualDDK to virtualbox. Then I run Vminstall.exe in virtualbox(guest). When I restart the guest the display shows invalid boot.ini and Widows starts normally. i.e it does not show the option of Start windows…. [VirtualKD] debugging mode. due to this my guest windows does not go in kernal debugging mode.
    Pleas give me any solution..
    Regards
    Khalid Ishaque
    #2251
    khalid Ishaque
    Hi Alls
    I have resolved this problem by editing the boot.ini file. go to My computer properties. then go to advanced and click Setting in the Startup and recovery. then click Edit. The boot.ini file will be open.
