interrupted install issue
Sysprogs forums Forums VisualGDB interrupted install issue
  • #10966
    thedixon
    If I am running install under a non-admin account, get to the point of system asking for an admin password, and then stop the installation – it leaves visual studio in unable to start state. Something gets triggered in privateregistry.bin in my VS appdata directory, that doesn’t let it start.
    #10970
    Sorry, this does not look like a VisualGDB-related bug. Normally it should not touch anything unless you go beyond the run-as-admin stage. This could be caused by some sort of a VS registry corruption or a corrupt installation. We would recommend trying to move away VS-related folders in your user account and restarting Visual Studio to recreate those folders.
    #10973
    thedixon
    It happened twice already (since I’m installing visual gdb bugfixed version a lot lately). I’d say it’s rather consistent. If I don’t interrupt the install process, and give it the admin password – it installs and works just great.
    #10974
    Strange. Can you confirm that just installing VisualGDB again solves the problem?
    #10977
    thedixon
    No it doesn’t. I have to delete privateregistry.bin after that everything works. Considering that the only thing that happens between vs working and not working is the interrupted visual gdb install I strongly want to blame it.
    #10993
    Sorry, could not reproduce this. The problem could easily be caused by a corrupt VS installation on one specific machine. Please try enabling the debug logging for the installer:
    msiexec /l* visualgdb.log /i VisualGDB.msi
    Then reproduce the problem and check for Visual Studio-related entries in the log file. This should explain what exactly is done by the installer.
