Interaction with Resharper
Sysprogs forums Forums VisualGDB Interaction with Resharper
  • #11252
    bumpyroad
    I’m running VisualGdb in VS2017. Everything builds ok using CMake, but intellisense has some odd behavior. For example the types declared in stdint.h such as uint32_t aren’t recognized by intellisense, even though /usr/include is in the intellisense directories. Is there something I’m missing here?
    #11253
    bumpyroad
    I tried running without Resharper, and the intellisense issues go away. Is there a way to reconcile the two addons?
    #11257
    The problem is that ReSharper uses its own IntelliSense engine that does not handle the GCC language extensions. So our best advice would be to use our Clang-based IntelliSense engine that is fully aware of those extensions and also offers advanced refactoring functionality.
    #11353
    borbmizzet
    See this thread:
    https://youtrack.jetbrains.com/issue/RSCPP-18095
    You need to manually include the folders for the standard library, because R# doesn’t realize you’re using gcc.
    Clang is still your best intelligent choice, as the above said, but that will let R# at least see your STL libraries if you want to use the other features of R#.
    • This reply was modified 8 years, 10 months ago by borbmizzet.
