Intellisense/Clang & gcc instrinsics
Sysprogs forums Forums VisualGDB Intellisense/Clang & gcc instrinsics
  • #8345
    MattK
    I have a macro that uses the gcc __typeof intrinsic:
    #define MAX(a,b) \
    ({ __typeof__(a) _a = (a); \
    __typeof__(b) _b = (b); \
    (_a > _b) ? _a : _b; })
    Intellisense is marking the macro calls as errors, since the __typeof intrinsic is unknown:
    (Error: Expected an expression).
    Is there anyway to make Intellisense ignore these “errors”? I hate seeing my scroll bar littered with little red dots for a perfectly good application!
    #8353
    Yes, please use the Clang IntelliSense engine. It is fully compatible with most of the Clang/GCC language extensions.
    #8358
    MattK
    I had disabled Clang to avoid some other issues.  Turning it on does indeed fix the gcc intrinsics.
    However, now the “Find Symbol Results [Clang]” window constantly flickers, and lines selected in its results are not visible:
    Lines not visible
    Additionally, I’m getting an error in the “Error List” window:
    [Clang Intellisense] Error: ‘C:\\Git\zebra\BSP\stm32_compat.h’ file not found
    Any help with these issues?
    #8366
    We have fixed the problems related to the Find Symbol Results window in this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.2.794.msi
    It also contains numerous improvements to the IntelliSense engine that make it much faster for large projects.
    You can resolve the stm32_compat.h problem by opening Visual Studio project properties (not VisualGDB Project Properties) and removing the stm32_compat.h file from the “Forced Includes” field.
    Let us know if you encounter further problems.
