Intellisense wrong parameter info
Sysprogs forums Forums VisualGDB Intellisense wrong parameter info
  • #24963
    MystikReasons
    I have a problem with the informations showed for the parameters.
    In my header of the function I have the following infopoints: (@brief, @param and @retval)
    See my screenshot for my function info and the structure of it.
    If I now call the function it looks like this (see screenshot #2)
    Is there a way to say it should take the informations from @param for the parameter informations?
    #24966
    It looks like the ‘*’ frame around the comment is interfering with the comment parsing logic.
    Please ensure that the line containing the ‘@param’ comment does not have any other characters (other then spaces) in front of the @param part and VisualGDB will handle it correctly.
    #24978
    MystikReasons
    I tried your suggestions but without any success. It still only displays the @brief informations.
    Is it because I’ve created the header with /* */ instead of ‘//’?
    And would it be possible to add a feature maybe inside Tools/Options/VisualGDB/IntelliSense where you can enter characters which should be ignored?
    That would be a huge relief because with the “*” it looks much cleaner in Visual Studio.
    See “screenshot #1” for the header which you suggested (withou ‘*’).
    Update: Now the parameter infos are weirder. It now displays the @brief informations and the @retval info instead of the @params. See screenshot #2
    And the function info is also weird now: It first displays the @brief informations then the @retval info and first at the end the @params info (see screenshot #3)
    • This reply was modified 6 years, 11 months ago by MystikReasons.
    #24984
    Please ensure that the parameter names after @param are not wrapped with any ‘<>’, e.g.:
    @param setting
