Intellisense stopped working
Sysprogs forums › Forums › VisualGDB › Intellisense stopped working
  • #10657
    sidprice
    I am working on an embedded project and Intelliense has been working, however this afternoon it no longer works. I have looked at my too options but it is still enabled. How can I fix this please, it is very annoying not to have it.
    Sid
    #10658
    It’s hard to say what could be causing this without seeing further details. One cause could be the header directories. Regenerating the project settings (e.g. by changing the MCU forth and back) could resolve this.
    If it does not help, please let us know the exact details of the errors you are getting and we will help you.
    #10668
    sidprice
    Thanks, however that did not help. There is no error I just don’t get any Intellisense “prompts when I am typing code. I suspect that I may have changed an option somewhere by accident. One thing I remember was a small colorful horizontal toolbar that popped up, perhaps I clicked on it by accident. However I don’t seem to be able to get it to appear again and I cannot find a setting to turn this back on.
    I did not change any project options just before this happened, this is aproject I have been working on for several months now.
    Sid
    #10677
    Please try pressing ‘Ctrl-Tab’ while typing your code to activate IntelliSense popup explicitly. If it helps, please click the lightning icon at the bottom of the popup to enable the “show suggestions as you type” mode.
    #10678
    sidprice
    That opens a popup but not the Intellisense popup. It shows the active tool window and active files list.
    Sid.
    #10679
    Sorry, that was Ctrl-Space, not Ctrl-Tab.
    #10680
    sidprice
    Much better, I get suggestions but I don’t see any methods or variables from my project.
    Sid
    #10681
    sidprice
    I think I may have got it. Using the dark theme it is impossible to know when an option is selected so I had to try each button in the toolbar until I got the result I expected.
    Sid.
    #10689
    Thanks for letting us know. We will consider making the button state more explicit for the dark theme.
