Sysprogs forums › Forums › VisualGDB › Intellisense disappearing Visual Studio 2022
- This topic has 1 reply, 2 voices, and was last updated 2 years, 8 months ago by
July 19, 2023 at 20:08 #34487
orbitcoms
ParticipantMaybe not related to Visual GDB but has anyone else experienced issue with intellisense hints disappearing a second or 2 after coming up?
Microsoft suggested removing third party extensions. I have removed all expect Visual GDB but issue still there.
Thanks in advance
July 20, 2023 at 17:27 #34498support
- Please make sure the steps do not involve any 3rd-party code as we will not be able to review it. If the problem only happens with a specific project, please make sure you can reproduce it on a clean project created from scratch. See this page for more information and detailed examples.
Another common cause of errors is updating to a new toolchain/BSP/SDK. Many of these components are maintained by device vendors or communities, and require minor adjustments to the project when switching to newer versions. If you have recently updated any of such components, please consider reverting back to the old version as described here. There is no need to downgrade VisualGDB itself, as it is updated separately from such components.
