Sysprogs forums › Forums › VisualGDB › Intellisense and CPPUTest issues
- This topic has 3 replies, 2 voices, and was last updated 8 years, 1 month ago by
August 13, 2018 at 01:17 #21654
surahman
I am having some issues configuring a CPPUTest project with the compiler reporting build error when it is unable to locate :
AppData/Local/VisualGDB/TestFrameworks/com.sysprogs.unittest.CppUTest/src/CppUTest/CommandLineTestRunner.cpp(34,31): error : SysprogsTestHooks.h: No such file or directory
#include “SysprogsTestHooks.h”The project is just the vanilla VGDB CPPUTest project wizard with MSBuild and WSL as the build tool and environment.
The other issue I have is with IntelliSense and it always marking code as incorrect. I have attached the IntelliSense Settings pane screenshot. I also have issue with adding directories to the IntelliSense Directories list:
VisualGDB version: 5.4.3.2346
—————— System.NotSupportedException ——————
System.NotSupportedException: The given path’s format is not supported.
at System.Security.Permissions.FileIOPermission.EmulateFileIOPermissionChecks(String fullPath)
at System.Security.Permissions.FileIOPermission.QuickDemand(FileIOPermissionAccess access, String fullPath, Boolean checkForDuplicates, Boolean needFullPath)
at VisualGDB.Common_GUI.WPF.MSBuildIntelliSenseSettingsPage.UpdateDirectoryList()
at VisualGDB.Common_GUI.WPF.MSBuildIntelliSenseSettingsPage.ImportSettings(a1 ctx)A screenshot of the code and the window that pops up indicating missing header files is attached. Manually locating and adding them does nothing but throw up the warning all over again. Is there anyway we can use visual assist with code completion or change the colour scheme that IntelliSense uses?
/SaadAttachments:
You must be logged in to view attached files.August 13, 2018 at 23:50 #21673support
Thanks for reporting this, looks like our bug introduced during a recent LXSS-related fix. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.4.2398.msi
August 14, 2018 at 16:13 #21675surahman
ParticipantYou are awesome, thanks, that fixed the issue. If anyone else runs into this issue in future make sure to delete the old template project and start with a fresh one using the new build because the old project will have issues.
On the windows display scaling side of things all the windows in the VGDB properties pane now scale properly except the Debug Properties page.
/Saad-
This reply was modified 8 years, 1 month ago by
surahman.
You must be logged in to view attached files.August 15, 2018 at 03:21 #21681support
Good to know it works.
Most of the pages look better on high-DPI displays as we have switched them to a more modern WPF technology. The Debug Settings page is one of the next property pages on our WPF conversion list.
