Sysprogs forums › Forums › WinCDEmu › Installation aborted!
- This topic has 4 replies, 2 voices, and was last updated 14 years, 7 months ago by
Anonymous.
July 31, 2010 at 07:13 #212
ParticipantHi..
When I install the version, it first prompts for a path.. then it shows a violet progress bar and instantly it shows a message box with message “Installation aborted”
I go check the folder and i find the following files in that.
115,200 batchmnt.exe
145,408 batchmnt64.exe
4,843 bazisvirtualcdbus.cat
1,458 BazisVirtualCDBus.inf
langfiles
104,600 uninstall.exe
124,928 uninstall64.exe
197,272 vmnt.exe
258,712 vmnt64.exe
x64
x86 I try using the command line to load files, but it returns me the following message.
Cannot connect to BazisVirtualCDBus.sys: The system cannot find the file specified.I tried copying the sys folder to C:windowssystem32drivers but it still doesnt help.
I run the portable version and it works fine.
Can somebody help me on this ?
July 31, 2010 at 08:21 #1466support
KeymasterDid you select “never install non-WHQL-signed drivers” in your system settings?
WinCDEmu now has a signed kernel-mode driver, but it was obviously not WHQL-certified.August 2, 2010 at 23:17 #1467Anonymous
ParticipantI tried to do the following based on your suggestion, but i still get the same error.
Goto My Computer, Click Properties, In the Hardware tab, click Driver Signing button.
I have tried setting the option to all three settings : Ignore, Block and Warn.
But I get the same error when using any of the three options.I am trying the install the “WinCDEmu-3.3-signed.exe”
I am on WinXP SP3November 26, 2010 at 19:54 #1468Anonymous
ParticipantI have also tried setting the “Code signing for device drivers” property to ignore in gpedit.msc under User ConfigurationAdministrative TemplatesSystem.
This also doesnt have any effect.Is there some kind of log that the installation generates that may be of use ?
September 6, 2011 at 00:56 #1469Anonymous
Participant@ikas wrote:
Hi..
langfiles
197,272 vmnt.exe
258,712 vmnt64.exe
x64
