Include folder (OpenCV)
Sysprogs forums Forums VisualGDB Include folder (OpenCV)
  • This topic has 1 reply, 2 voices, and was last updated 12 years ago by ket.
  • #585
    Nagilo
    I’m using the trial version of the VisualGDB with VisualStudio 2010. So far, I’m very pleased with it and we will buy the full version soon.
    Anyway, currently I’m trying to set up a project that uses OpenCV. In the project configuration page I set the (local) include-directory to the folder, where the OpenCV *.h and *.hpp files are located. But when I then use
    #include
    in my source code, the compiler says:
    error : opencv2/opencv.hpp: No such file or directory
    What am I doing wrong? Or do I need to use the VisualGDB Source Cache Manager instead?
    Many thanks in advance
    #2469
    ket
    For Linux/Embedded/cygwin/MinGW projects the include paths should be specified in flags.mak, for Android projects in Android.mk. Also, for remote projects the path specified should be the path on the remote build machine as that is where the Makefile will be used.
    Additionally in the VisualGDB Project Properties you can specify IntelliSense includes that are used by Visual Studio IntelliSense.
    The VisualGDB Source Cache Manager caches remote sources locally for them to be browsable and accessible to IntelliSense, it is not related to include directories.
