Sysprogs forums › Forums › VisualGDB › Imported STM32CubeIDE project missing some things
- This topic has 2 replies, 2 voices, and was last updated 4 years, 7 months ago by
GeneM.
June 27, 2021 at 11:35 #30786
GeneM
ParticipantI created a project using STM32CubeIDE to get a start on setting the pin mappings and clock setup and other infrastructure correctly. When I import the project into VisualGDB using the Embedded Project Wizard > Automatically import a project in a different format > Import an existing STM32CubeIDe/SW4STM32 Project, some of the subroutines in the original STM32CubeIDE project don’t get imported into the new VisualGDB project and I don’t seem to be able to find them anywhere in the new project. For example. The STM32CubeIDE project starts with this.
int main(void)
/* USER CODE BEGIN 1 *//* USER CODE END 1 *//* MCU Configuration--------------------------------------------------------*//* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();/* USER CODE BEGIN Init *//* USER CODE END Init *//* Configure the system clock */
SystemClock_Config();/* USER CODE BEGIN SysInit *//* USER CODE END SysInit *//* Initialize all configured peripherals */
MX_GPIO_Init();
MX_DMA_Init();
MX_USART1_UART_Init();
MX_USART2_UART_Init();
MX_I2C2_Init();
MX_I2C3_Init();
MX_I2C4_Init();
MX_IWDG1_Init();
MX_LPTIM1_Init();
MX_LPTIM3_Init();
MX_LPUART1_UART_Init();
MX_UART4_Init();
MX_UART7_Init();
MX_UART8_Init();
MX_UART9_Init();
MX_USART3_UART_Init();
MX_USART6_UART_Init();
MX_USART10_UART_Init();
MX_OCTOSPI1_Init();
MX_OCTOSPI2_Init();
MX_RTC_Init();
MX_SPI1_Init();
MX_SPI2_Init();
MX_USB_OTG_HS_USB_Init();
MX_WWDG1_Init();
MX_FATFS_Init();
MX_SDMMC1_SD_Init();
MX_SPI4_Init();
/* USER CODE BEGIN 2 *//* USER CODE END 2 *//* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE *//* USER CODE BEGIN 3 */
}And the new VGDB project starts with this.
int main(void)
MX_GPIO_Init();
while (1)
/* USER CODE END 3 */
}None of the subroutines after
MX_GPIO_Init();seem to be anywhere in the new project. I have both projects zipped up but it’s too big to attach here.
June 28, 2021 at 08:18 #30790support
Please double-triple check that you are importing the correct project. The import logic of the wizard never generates any new files, it simply references existing files linked by the project file. You can find out the full path of the file containing the main() function by right-clicking on the tab header in Visual Studio and selecting “Copy full path”. You can then compare it with the path of the file in the original STM32CubeIDE project.
July 1, 2021 at 22:59 #30843 -
