Import Folder Missing
Sysprogs forums Forums VisualGDB Import Folder Missing
  • #25156
    MikeGranby
    For some reason, the wonderfully useful recursive “import folder” option seems to have disappeared from my VS 2010 installation with Visual GDB Custom. Doesn’t seem to be present in VS 2017 or VS 2019. Any ideas?
    #25159
    Please double-check that other VisualGDB commands are present and that the Import Folder command was not explicitly hidden via Tools->Customize.
    If nothing helps, please share a screenshot of the About VisualGDB window from the same VS version, and also a screenshot of the entire screen showing Solution Explorer and the context menu where the “Import folder” command would normally appear, so that we could try to understand what is going on.
    #25160
    MikeGranby
    Okay. I found it. It’s disabled when I’ve got the project in the Win32 configuration, but it comes back if I flip to one of my custom Linux configurations. (I’m not using VisualGDB’s configuration type, but instead some custom MSBuild magic.) Sorry for the false alarm! I’ll get my coat… πŸ™‚
    #25161
    No worries. BTW, as long as VisualGDB is fully initialized (either when you create/open a compatible project, or just run the Help->About VisualGDB command), the “import folder” command should appear for all .vcxproj projects, even if they are not based on VisualGDB.
