Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › How to set Target machine hostname or IP on with VirtualBox
- This topic has 9 replies, 2 voices, and was last updated 15 years, 8 months ago by
Anonymous.
October 1, 2009 at 23:34 #83
ParticipantHi all,
I cannot fix the issue “Attaching the DDK debugger to process ‘[0] System’ on machine ‘PHENOM2’ failed.” now.
Do you have any solution for fixing this problem.
I would like to use the latest VisualDDK and VirtualKD on Windows7 x86 and VirtualBox(WIndows XP x64 and etc…)
It could be occured due to setting wrong hostname or IP to the “Driver Launch Settings… ” on VS2008SP1, I guess.Thank you very much for your cooperation.
Best Regards,
Akira Kudo
PS… I have confirmed working a sample code that is made by the VisualDDK Driver Wizard on VirtualBox “WIndows XP x64 and Vista x64” using the WinDDK and the Virtual Machine Monitor.Than you very much for Blilient environment “VirtualDDK and VirutalKD”!
October 2, 2009 at 12:07 #1066support
KeymasterDoes the VirtualKD with WinDbg work on your machine? If not, what does the VM monitor show?
October 3, 2009 at 11:48 #1067Anonymous
ParticipantHi bazis,
Thank you very much for your reply.
Yes, the VirtualKD works with WinDbg on my machine.
Do we need to install newrk brigde to host and guest OS?Again, thank you very much for your cooperation.
Best Regards,
AKiraOctober 3, 2009 at 16:59 #1068support
KeymasterBridging is required for automatic driver binary updating, however, is not mandatory for debugging with VisualDDK. If WinDbg/VirtualKD works, and VisualStudio with VisualDDK fails, you can try using Debug->Attach command, selecting “Kernel-mode connections” and picking your OS manually. You will get either a working debug session, or a more detailed error message.
October 6, 2009 at 14:17 #1069Anonymous
I will be trying it soon! Please hold on.
Again, thank you very much for your cooperation.Best Regards,
AKiraAkiraOctober 6, 2009 at 15:35 #1070Anonymous
ParticipantHi Bazis,
Attach to Process
Transport: Kernel-mode connections
Qualifier: pipe://kd_Windows7_x86_English_Debug…Unable to connect to ‘pipe://kd_Windows7_x86_English_Debug’. All pipe instances are busy.
Any idea?
I am trying to do it with some processes, Virtual Machine monitor, Visual Studio, WinDbg, Sun Virtual Box and Windows7 x86 English Debug.
Best Regards,
Akira KudoOctober 6, 2009 at 16:01 #1071support
KeymasterWell, if you are already debugging your machine with WinDbg, how can VisualDDK attach to it? The pipe is obviously occupied by WinDbg instance. However, if you close the WinDbg (and uncheck ‘automatically start the debugger’ in VMMON, or just close VMMON, as it is no needed for VisualDDK), debugging from VisualDDK should work.
October 8, 2009 at 12:23 #1072Anonymous
It works fine!!
Thank you very much for your cooperation.Best Regards,
Akira KudoPS … Is it possible to ask you how you did set network bridge for Virtual Box? Maybe everybody want to know it.
November 22, 2009 at 07:03 #1073support
KeymasterI just created 2 network adapters: 1 NAT adapter to have Internet on VM, and 1 host-only adapter to access VM from host. A bit messy, but fast and easy.
May 29, 2010 at 07:12 #1074Anonymous
ParticipantHi all,,
Help me, im a newbie for driver debugging
i was install visualddk in visual studio 2008 team system, and im using VirtualBox v3.0.8
but i can’t syncronyze visualddk with VirtualBox
this is output:
Help me please,, and show me the right configuration…
