Complex projects like Qemu usually handle dependencies different from each other, so VisualGDB doesn’t provide any special interface for managing them. Hence, the easiest way to debug a tool like Qemu would be to use the Quick Debug feature.
Another option would be to run the configure step manually, ensure that the “Make” command succeeds from the command line and then import the project as an external project built with command-line tools. When VisualGDB asks for the build command-line, you can specify the following to trigger an msys-based build with the correct environment:
- Command: <path to mingw>\usr\bin\bash.exe
- Arguments: –login -c “cd <directory> && make”
Debugging normally does not require the special environment, hence using the regular settings to specify the debugged executable should work.
