Sysprogs forums › Forums › VisualGDB › How to create a new ESP-IDF v5 project
- This topic has 4 replies, 2 voices, and was last updated 3 years ago by
paulh001.
March 11, 2023 at 09:01 #33973
paulh001
ParticipantHi
I want to create a new ESP-IDF project, I would expect an option to choose the ESP-IDF options I need but I can only choose example projects?
How can I create a project with for example support for lcd (ili9341), wifi, sockets, I2c etc. ?
Is there an option to do so?
March 11, 2023 at 22:50 #33974support
This is by design. VisualGDB can automatically do things that are, well, automatable. ESP-IDF comes with various examples that can be built using the same CMake interface, so VisualGDB can automatically clone and build them for you. ESP-IDF uses KConfig to edit various configuration parameters, so VisualGDB offers a neat searchable GUI for working with them.
To our best knowledge, ESP-IDF does not come with a machine-readable description that would cover the functionality you described, hence VisualGDB cannot automatically do it.
March 12, 2023 at 04:51 #33975paulh001
Thanks, I did some research and I think for now I merge several examples into one template. I see that VisualGDB reads the kconfig file so I can edit it to merge the example menu’s. I only cannot find this file in the solution explorer.
The only (minor) issue I have is that VisualGDB somehow delete the components which I added to the project using the component yaml file. When I select Reload Cmake Project the components are dowloaded again. But when you reconfigure the project options the components are delete.
Thanks, for the quick response.
March 12, 2023 at 19:03 #33981support
- Please make sure the steps do not involve any 3rd-party code as we will not be able to review it. If the problem only happens with a specific project, please make sure you can reproduce it on a clean project created from scratch. See this page for more information and detailed examples.
March 14, 2023 at 13:01 #33987paulh001
I recreated the project, now it seems ok
