How do I set LD_LIBRARY_PATH for the debugged application?
Sysprogs forums › Forums › VisualGDB › How do I set LD_LIBRARY_PATH for the debugged application?
  • #451
    BitFlipper
    Sorry, I’m asking a lot of questions here…
    The application being debugged needs to have LD_LIBRARY_PATH set to a specific value. I don’t want to set the global environment variable, just the application being debugged. Previously when I did not debug the application – just ran it, I ran a bash script that called “export” with the value for LD_LIBRARY_PATH. However, now that I’m debugging it, I’m not sure how to specify it.
    I tried to run the command “export” as a separate step before debugging, however it seems it doesn’t work because it is run as a separate process and hence the debugged application doesn’t see it. How do I set the environment variables for the debugged application?
    Thanks in advance for any help
    #2120
    BitFlipper
    OK figured it out. I needed to add it to the environment variables listed under the GDB Customize settings.
    #2121
    blitz
    Where exactly did you do this in VisualGDB? User-Variables?
    Simply putting in LD_LIBRARY_PATH and the path (ie /usr/lib)?
    Thanks Blitz
    #2122
    Please open VisualGDB Project Properties window, go to the Debug Settings page, select “use custom GDB executable”, click “Customize” and update the “Additional Environment Variables” line.
