High memory consumption when mounting image from network drive
Sysprogs forums Forums WinCDEmu High memory consumption when mounting image from network drive
  • This topic has 0 replies, 1 voice, and was last updated 10 years ago by stw.
Viewing 1 post (of 1 total)
  • #7233
    stw
    as already mentioned in the title I’m running into an issue regularily, which occurs when I mount an image from a network drive and execute e.g. an install program (or any other program) on the mounted image.
    The system memory consumption increases until no more memory is available until I eject the virtual drive.
    For a more detailed description, see the ticket on GitHub, that I’ve created:
    https://github.com/sysprogs/WinCDEmu/issues/10
    I’d really be happy if you could fix that issue.
    Thank you!
