Graphical Designer for .ui files
Sysprogs forums Forums VisualGDB Graphical Designer for .ui files
  • #9886
    hfrmobile
    Since I like to use Qt + Visual Studio/GDB it would be helpful having a graphical designer for .ui files instead of doing UI design only in XML. Exists there something like in Eclipse?
    #9893
    We recommend installing the Windows build of Qt and then using Qt Designer from it to edit the .ui files. If you install the Qt VS add-in, it will automatically open the Qt designer once you click at a .ui file in Visual Studio.
