Sysprogs forums › Forums › VisualGDB › -gdb-version taking too long to complete
- This topic has 5 replies, 2 voices, and was last updated 2 years, 7 months ago by
ews.
August 23, 2023 at 07:42 #34606
ews
ParticipantWhenever I start a new hardware debugging session I get the message “The following GDB command is taking too long to complete: -gdb-version” and there is a 20 second wait before I can proceed. This just started happening with the last Visual GDB update I installed. Uninstalling/re-installing Visual GDB has not helped. Any suggestions as to what to try next?
Thanks!
You must be logged in to view attached files.August 23, 2023 at 15:03 #34608support
The -gdb-version is the first command sent by VisualGDB to GDB. If it times out, it means that the GDB executable takes that long to initialize. You can try running it manually with the same arguments used by VisualGDB and see if there is any pattern.
The delay can also be caused by your antivirus or could be related to the latest ARM toolchain that takes considerably longer to load some symbols. If it only happens for embedded ARM projects and reverting to an older toolchain fixes it, please let us know and we will investigate it more.
August 24, 2023 at 13:55 #34611ews
ParticipantThanks for the response. I tried running GDB from the command line and it seems to be taking a long time on the step
~”Reading symbols from <project name>…\n”
where it hangs up for around 20 seconds, same as when I was running it via VisualGDB. After that I could interact with GDB via the command line and it responded quickly.
I have no idea if this is related but there were some warnings while re-building the project that I don’t recall seeing before:
Linking ../VisualGDB/Debug/fwip…
c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.2.1/../../../../arm-none-eabi/bin/ld.exe: c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.2.1/thumb/v7e-m+fp/hard\libc_nano.a(libc_a-fstatr.o): in function `_fstat_r’:
fstatr.c:(.text._fstat_r+0xe): warning: _fstat is not implemented and will always fail
c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: ../VisualGDB/Debug/fwip has a LOAD segment with RWX permissionsI’ll see if I can change the ARM toolchain and get a different outcome next.
August 24, 2023 at 15:38 #34613support
KeymasterThanks, this looks like a known issue of the new toolchain. We are not aware of any workarounds yet, so if it is affecting you, please consider downgrading it until we figure out a better solution.
The warning message you mentioned is described here: https://visualgdb.com/documentation/semihosting/#notimpl
August 29, 2023 at 11:00 #34642support
KeymasterUpdate: We have run some additional tests and it looks like the problem only happens with the gdb binaries shipped with the original ARM toolchain. We built the latest gdb 13.2 from sources, and it manages to load the symbols instantly, just like the older gdb versions.
We have published an updated ARM toolchain that replaces the GDB binary with the one we built. You can install it via VisualGDB Package Manager or directly from here: arm-eabi-gcc12.3.1.exe
September 6, 2023 at 11:50 #34688ews
ParticipantI tried out the updated toolchain and it worked perfectly. Thank you for the excellent support!
