Gdb hangs. -target-select remote :XXXXX
Sysprogs forums Forums VisualKernel Gdb hangs. -target-select remote :XXXXX
  • #952
    I’m trying for few hours now to set up your program and no luck yet. I’m using the network method (Ethernet) and everytime I try to debug the target machine (the ubuntu) stucks (like it should) and I get the following annoying message in the host pc:
    The following GDB command is taking too long to complete:
    -target-select remote :49213 // or any other port, seems to be random
    and after a min or so it just stops and I have to restart the target machine.
    What’s wrong with the connection between the two computers? Everything seems ok when it comes to compiling/building etc so there’s a connection ofc. What am I doing wrong ?
    would love to hear some suggestions.
    #3499
    I use virtual machines (vmware) and Ethernet works fine.
    #3500
    Ok. I don’t use vmware. Would love to hear some Helpful comments.
    #3501
    What ethernet card are you using? Kgdboe (Ethernet debugging transport) can be incompatible with some cards. What happens if you try setting up KGDBoE manually (http://sysprogs.com/VisualKernel/kgdboe/tutorial/)? Do you get a connection? Do you get any errors in dmesg?
