FreeRTOS-Demo does not compile
Sysprogs forums Forums VisualGDB FreeRTOS-Demo does not compile
  • #30242
    runout
    I try to run a FreeeRTOS-Demo (exactely CORTEX_M7_STM32F7_STM32756G-EVAL_IAR_Keil from “FreeRTOSv202012.00”)
    Everthing runs fine BUT…
    One single File does not compile!
    “RegTest_Keil.c” – This File contains some ASM-Functions
    __asm void vRegTest1Implementation( void )
    PRESERVE8
    IMPORT ulRegTest1LoopCounter
    /* Fill the core registers with known values. */
    mov r0, #100
    mov r1, #101
    mov r2, #102
    mov r3, #103
    mov r4, #104
    mov r5, #105
    mov r6, #106
    Error-Messages:
    Error expected ‘(‘ before ‘void’ RTOSDemo..
    Severity Description Project File Line
    Error stray ‘#’ in program RTOSDemo..
    Maybe the Syntax is wrong…
    Maybe an Include is missed…
    Need a little nudge 😉
    #30243
    runout
    also to keep in mind:
    the Project was imported by the VGDB-Wizard from a Keil-Source…
    #30245
    Please note that our support is limited to VisualGDB issues only. Based on the information you provided, VisualGDB is working as expected – the compiler reports a build error and VisualGDB displays it.
    Please note that we receive a large volume of inquiries asking to help troubleshoot a specific project, port a library to a different device, or fix a build error, and are not able to investigate them without directly billing the users for the time required to do that.
