Sysprogs forums › Forums › Other tools & products › Fixing -rpath-link issues with cross-compilers
- This topic has 1 reply, 1 voice, and was last updated 10 years, 5 months ago by
frankc.
May 8, 2016 at 04:53 #8180
frankc
Participant<div>I was wondering if your approach of creating the<span style=”font-family: Thread-00000bb8-Id-00000252;”> ld.so.conf</span> file in the correct folder</div>
<div>could be used to solve the problem where I am trying to build an ArmV6 executable</div>
<div>in our Ubuntu 16.04 instance containing both a recently downloaded ARM v6</div>
<div>arm-linux-gnueabi-g++-4.6.3 compiler and preinstalled(i.e LiveCD Ubuntu 16.04 iso)</div>
<div>ARM v7 arm-linux-gnueabi-g++-5.3.1 compiler which does not</div>
<div>SIGSEGV when it is “pscp-ed” and executed in the /home/pi folder of my Raspian</div>
<div>ARMv6 Wheezy emulator mounted on an SD card. Here are the bash command line</div>
<div>statememts I used to build this problematic executable:</div>
<div>1. arm-linux-gnueabi-g++-4.6.3 -o Program.o -g -DLINUX -fPIC -c Program.cpp</div>
<div>2. arm-linux-gnueabi-ld-4.6.3 -o Program.exe</div>
<div>-L /home/frank/tools/usr/lib/arm-linux-gnueabi -lgcc_s -L /home/frank/tools/usr/lib/arm-linux-gnueabi -lc</div>
<div>When I run strace on command line statement #2, I noticed that I am</div>
<div>picking up stray unintended Ubuntu 16.04 instance Armv7 libraries and object files</div>
<div>in the /usr/lib/arm-linux-gnueabi folder. Could that possibly cause a</div>
<div>SIGSEGV? May I ask the best way to build an ARMv6 executable in my</div>
<div>heterogenous ARMv6-g++ and ARMv7-g++ compiler situation which does segfault when copied and</div>
<div>executed on the Raspian Wheezy emulator? Thank you.</div>May 8, 2016 at 05:48 #8181frankc
ParticipantPlease ignore my previous post.
I was wondering if your approach of creating the ld.so.conf file in the correct folder
statements I used to build this problematic executable:
picking up unintended Ubuntu 16.04 instance Armv7 libraries and object files
in the /usr/lib/arm-linux-gnueabi folder. Could that or something else I did cause a
SIGSEGV? May I ask the best way to compile and link an ARMv6 executable in my
heterogenous ARMv6-g++ and ARMv7-g++ compiler situation which does not segfault when copied and
executed on the Raspian Wheezy emulator? Thank you -
