Sysprogs forums › Forums › VisualGDB › First embedded project throws java error
- This topic has 1 reply, 2 voices, and was last updated 3 years, 2 months ago by
December 23, 2022 at 13:25 #33596
jerryc4174
ParticipantI have just installed visualgdb and tried to create a STM32cubemx project. Once I had selected the processor STM32F429ZIT, I hit next and I got an error message
You must be logged in to view attached files.December 24, 2022 at 18:06 #33598support
- Please make sure the steps do not involve any 3rd-party code as we will not be able to review it. If the problem only happens with a specific project, please make sure you can reproduce it on a clean project created from scratch. See this page for more information and detailed examples.
Another common cause of errors is updating to a new toolchain/BSP/SDK. Many of these components are maintained by device vendors or communities, and require minor adjustments to the project when switching to newer versions. If you have recently updated any of such components, please consider reverting back to the old version as described here. There is no need to downgrade VisualGDB itself, as it is updated separately from such components.
