There exists a capability in Windows to alias a COM port with the change port command.
VisualGDB only lists actual hardware COM ports in the dropdown selectors.
For example, if I have some example projects that use a COM9 port, it would be helpful if the end user could just alias their local COM part to match, rather than having to adjust each of the projects to the actual hardware port.
change port com9=com23
change port /QUERY
results in
COM22 = \Device\Serial19
COM23 = \Device\Serial2
COM9 = \Device\Serial2
VisualGDB does work when connecting to the aliased COM ports, (e.g. the raw terminal to COM9) when manually typed, even though COM9 does not actually appear in Device Manager (an alias, as assigned above).
This feature request is just for the dropdowns to list the aliased ports in addition to the actual physical ones.
Thank you.
