Feature request: Create empty project
Sysprogs forums › Forums › VisualGDB › Feature request: Create empty project
  • #7907
    julianr
    It would be nice if it would be possible to create an empty project with just the startup, the system file and an empty main.
    I am still in the process of evaluating the the STM32F103 for private use and I would like to try various ready to use libs and hal implementations besides the one that is provided by ST. For this a new clean project is the best base.
    At work we use Keil µVision and creating a new project here results in an empty project with just the startup file. The same would be nice for VisualGDB. Just add the option “empty” in the sample selection screen.
    #7918
    You can easily remove all extra files from the project by unreferencing the HAL library in VisualGDB Project Properties -> Embedded Frameworks.
    #24548
    raitraak
    +1
    #28145
    tajen
    +1
    This is still a feature that is wanted.
    And should be easy to add as well.
    #28146
    No problem, we have updated VisualGDB to show an “empty project” template after the regular project samples in the embedded project wizard. Please try this build: VisualGDB-5.5.5.3622.msi
    You can turn this feature on and off via the “Show Empty Project Template” setting (see this page for a list of all global settings).
    #28147
    tajen
    Thanks. Works fine.
