Sysprogs forums › Forums › VisualGDB › Failed to run confgey.py for ESP32 with kconfig type hex
- This topic has 9 replies, 2 voices, and was last updated 7 years, 2 months ago by
December 30, 2018 at 22:54 #23201
doingnz
I am trying to create a VisualGDB project that builds the TFT Library found here: https://github.com/loboris/ESP32_TFT_library
I have resolved all but one issue. If I add the following definition for SPIFFS_BASE_ADDR to Kconfig.projbuild as per the original github repository, then I get an error “Failed to run confgen.py”
config SPIFFS_BASE_ADDR
hex “SPIFFS Base address”
range 100000 1FFE000
default 180000
help
Starting address of the SPIFFS area in ESP32 FlashIt fails to parse the 1FFE000 as hex.
Output is as follows:
Traceback (most recent call last):
File “C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/confgen.py”, line 292, in <module>
main()
File “C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/confgen.py”, line 106, in main
output_function(config, temp_file)
File “C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/confgen.py”, line 258, in write_json_menus
config.walk_menu(write_node)
File “C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/kconfiglib.py”, line 966, in walk_menu
callback(node)
File “C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/confgen.py”, line 232, in write_node
greatest_range = [int(min_range.str_value), int(max_range.str_value)]
ValueError: invalid literal for int() with base 10: ‘1FFE000’The projects builds if I change the above to int and convert hex to decimal as follows.
int “SPIFFS Base address”
range 1048576 33546240
default 1572864
help
Starting address of the SPIFFS area in ESP32 FlashIs VisualGDB missing support for “hex” parameters or something I have done incorrectly?
Thanks for the help.
This topic was modified 7 years, 2 months ago by
doingnz. Reason: removed Kconfig.projbuild attachement as it is not permitted
December 31, 2018 at 00:25 #23209support
Thanks for the email address update. We have linked the new email address to your forum profile.
Regarding the problem, is looks like you are missing the “0x” prefix (e.g. see how PARTITION_TABLE_OFFSET is defined in esp-idf\v3.1\components\partition_table\Kconfig.projbuild).
December 31, 2018 at 00:39 #23210doingnz
ParticipantThe project is now running on the ESP32-WROVER-KIT v4.1 with the workaround of using the int and decimal values in place of the HEX.
There are a couple of other small edits from the original library. Demo not perfect, but runs blinky + tft_demo as tasks.
Attached Zip of project if anyone wants to play further.
December 31, 2018 at 00:42 #23211doingnz
ParticipantTry that attachment again after deleting the folders ‘mkspiffs’ and ‘spiffs_image’. The original folders available from github repo as no changes relevant to running on ESP32
You must be logged in to view attached files.December 31, 2018 at 00:47 #23214doingnz
ParticipantI tried adding the 0x prefix earlier. Still fails, but with a different error. i.e. with
config SPIFFS_BASE_ADDR hex “SPIFFS Base address” range 0x100000 0x1FFE000 default 0x180000 help Starting address of the SPIFFS area in ESP32 Flash
error is
Traceback (most recent call last): File "C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/confgen.py", line 292, in <module> main() File "C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/confgen.py", line 106, in main output_function(config, temp_file) File "C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/confgen.py", line 258, in write_json_menus config.walk_menu(write_node) File "C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/kconfiglib.py", line 966, in walk_menu callback(node) File "C:/SysGCC/esp32/esp-idf/v3.1/tools/kconfig_new/confgen.py", line 232, in write_node greatest_range = [int(min_range.str_value), int(max_range.str_value)] ValueError: invalid literal for int() with base 10: '0x100000'
December 31, 2018 at 00:56 #23215doingnz
ParticipantThe problem appears to be with “range”.
i.e. this is OK
config SPIFFS_BASE_ADDR hex “SPIFFS Base address” default 0x180000 help Starting address of the SPIFFS area in ESP32 Flash
but this is not
December 31, 2018 at 01:13 #23216doingnz
Participantif I specify:
config SPIFFS_BASE_ADDR hex “SPIFFS Base address” default 0x180000 range 1048576 33546240 help Starting address of the SPIFFS area in ESP32 Flash
It will build, and VisualGDB UI for PROJECT PROPERTIES will require value to be entered as hex prefixed with ‘0x’, but it will ignore the range check. i.e. I can enter 0x100 and it will be saved as the config value.
Obviously not an urgent fix as I can build and run the project. 🙂
December 31, 2018 at 06:03 #23217support
Thanks for the very detailed description. We have rechecked this and it indeed looks like the logic for handling the ranges for hex entries still expects decimal values.
This is logic, however, is a part of the ESP-IDF itself and is unfortunately outside of VisualGDB’s control. Please consider submitting a bugreport in the ESP-IDF bugtracker for this.
The range checking is indeed not yet supported by VisualGDB, sorry. We will try to add it in one of the next releases, although we have a few other features queued (e.g. ESP32 unit test integration) ahead of that.
December 31, 2018 at 12:57 #23227doingnz
ParticipantBefore i create an issue in ESP-IDF bugtracker, thoughts why the following works under msys32 build without ‘0x’ prefix, but in VisualGDB environment requires ‘0x’ prefix for default and range cannot be hex?
config SPIFFS_BASE_ADDR hex "SPIFFS Base address" range 100000 1FFE000 default 180000 help Starting address of the SPIFFS area in ESP32 Flash
December 31, 2018 at 18:21 #23228support
Strange. We tried the example above and ESP-IDF failed to parse it (100000 and 180000 are valid decimal values as well, but 1FFE000 caused it to crash). If it doesn’t fail in your msys32 environment, please double-check that you are using the same versions of ESP-IDF (perhaps it has already been fixed in the master branch of ESP-IDF).
