Failed to clone NRFConnect SDK
Sysprogs forums Forums VisualGDB Failed to clone NRFConnect SDK
  • #28338
    SdB
    Moin,
    I tried to create a project using the new NRFConnectSDK support with VisualGDB 5.5  Preview 7, build 3666. Unfortunately the creation failed during cloning of the NRFConnectSDK (see log file content below).
    Does the SDK support require a certain version of Python to be installed? Could you please give me a hint about the possible root cause of the error?
    Best regards,
    Stefan
    Log file content:
    Run “C:\SysGCC\NRFConnectSDK\v1.2.0\python-env\scripts\python.exe -m pip install west” in directory “” on local computer
    DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
    ERROR: Could not find a version that satisfies the requirement west (from versions: none)
    ERROR: No matching distribution found for west
    Command exited with code 1
    #28345
    SdB
    Nevermind, I was not aware that VisualGDB uses its own python environment. I found the old python package 2.7 in the package manager, removed it and installed python 3.7. Now I’m able to create a NRFConnectSDK based project.
    #28350
    Good to know it works. VisualGDB can indeed install a Python environment that was tested on our side with the nRFConnect SDK and should work out-of-the-box (see step #7 of our NRFConnect tutorial). In case of any Python-related problems, we suggest resetting the environment as shown on this page.
