Failed to clone ESP-IDF
Sysprogs forums Forums VisualGDB Failed to clone ESP-IDF
  • This topic has 2 replies, 2 voices, and was last updated 7 years ago by vard.
  • #20840
    vard
    Hi everyone!
    I just upgraded from 5.3 to 5.4 and I wanted to setup a new project. I tried to checkout ESP-IDF v3, I selected “Latest Experimental (master)” option, kept my target directory as C:\SysGCC\esp32\esp-idf\master, but I’m getting this VisualGDB error:
    VisualGDB version: 5.4.3.2193
    System.Exception: Failed to clone ESP-IDF. Check git output.
    at t11.k.b(rq1 a)
    at VisualGDB.Common_GUI.WPF.ItemizedProgressWindow.<>c__DisplayClass1_0`1.<RunAction>b__0()
    Any suggestions?
    I’m on Win 10 Pro x64, version 1709, using VS2017
    Thanks!
    #20841
    It looks like something is preventing the git command to clone theĀ ESP-IDF repository. Please check theĀ output of the git command shown in the progress window for clues. If you are not sure, please post it here and we can help you understand it.
    #20842
    vard
    Thank you very much for the fast response, it looks like I had an issue with the toolchain and the path on my PC. I re-installed it and everything seems to be fine now.
    All the best!
