Sysprogs forums › Forums › VisualGDB › Failed to build Test Project for Cross compiled QT at BeagleBoard Black
- This topic has 1 reply, 2 voices, and was last updated 5 years, 7 months ago by
December 28, 2020 at 10:43 #29731
Grkan
ParticipantHello,
I’m trying to build a simple project for Beagleboard Black. I’ve installed Microsoft Visual Studio Community 2019 and VisualGDB. I was following this tutorial (https://visualgdb.com/tutorials/beaglebone/qt5/app/)
It has installed all the necessary packages on host and target and created the project. But when I try to build I’m getting the following error. Can you please help to solve the issue?
C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe
[1/3] Automatic MOC and UIC for target LinuxProject2
[2/3] Building CXX object CMakeFiles/LinuxProject2.dir/LinuxProject2_autogen/mocs_compilation.cpp.o
FAILED: CMakeFiles/LinuxProject2.dir/LinuxProject2_autogen/mocs_compilation.cpp.o
C:\SysGCC\beaglebone\bin\arm-linux-gnueabihf-g++.exe –sysroot=C:/SysGCC/beaglebone/arm-linux-gnueabihf/sysroot -DQT_CORE_LIB -DQT_GUI_LIB -DQT_WIDGETS_LIB -I. -I../../../ -ILinuxProject2_autogen/include -isystem C:/SysGCC/beaglebone/arm-linux-gnueabihf/sysroot/usr/include/arm-linux-gnueabihf/qt5 -isystem C:/SysGCC/beaglebone/arm-linux-gnueabihf/sysroot/usr/include/arm-linux-gnueabihf/qt5/QtWidgets -isystem C:/SysGCC/beaglebone/arm-linux-gnueabihf/sysroot/usr/include/arm-linux-gnueabihf/qt5/QtGui -isystem C:/SysGCC/beaglebone/arm-linux-gnueabihf/sysroot/usr/include/arm-linux-gnueabihf/qt5/QtCore -isystem C:/SysGCC/beaglebone/arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/qt5/mkspecs/linux-g++ -g -fPIC -MD -MT CMakeFiles/LinuxProject2.dir/LinuxProject2_autogen/mocs_compilation.cpp.o -MF CMakeFiles\LinuxProject2.dir\LinuxProject2_autogen\mocs_compilation.cpp.o.d -o CMakeFiles/LinuxProject2.dir/LinuxProject2_autogen/mocs_compilation.cpp.o -c LinuxProject2_autogen/mocs_compilation.cpp
In file included from LinuxProject2_autogen/mocs_compilation.cpp:2:0:
LinuxProject2_autogen/EWIEGA46WW/moc_MainWindow.cpp:22:1: error: ‘QT_WARNING_DISABLE_DEPRECATED’ does not name a type
LinuxProject2_autogen/EWIEGA46WW/moc_MainWindow.cpp:32:14: error: ‘qt_meta_stringdata_MainWindow_t’ does not name a type
static const qt_meta_stringdata_MainWindow_t qt_meta_stringdata_MainWindow = {
LinuxProject2_autogen/EWIEGA46WW/moc_MainWindow.cpp:78:1: error: ‘QT_INIT_METAOBJECT’ does not name a type
QT_INIT_METAOBJECT const QMetaObject MainWindow::staticMetaObject = {
LinuxProject2_autogen/EWIEGA46WW/moc_MainWindow.cpp: In member function ‘virtual void* MainWindow::qt_metacast(const char*)’:
LinuxProject2_autogen/EWIEGA46WW/moc_MainWindow.cpp:92:26: error: ‘qt_meta_stringdata_MainWindow’ was not declared in this scope
if (!strcmp(_clname, qt_meta_stringdata_MainWindow.stringdata0))
ninja: build stopped: subcommand failed.
Command exited with code 1
Executable: C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe
Arguments:
Directory: D:\Projects\BeagleBone-Firmware\Test1\LinuxProject2\LinuxProject2/build/VisualGDB/Debug
Command-line action failed========== Project Build Summary ==========
LinuxProject2 built in 00:00
========== Build: 0 Succeeded, 1 Failed, 0 Skipped ==========December 28, 2020 at 10:45 #29732support
Sorry, our support covers VisualGDB issues only. We are not able to help troubleshoot specific projects without directly billing for the time required to do such troubleshooting.
Please consider posting on Qt and/or Beaglebone forums for further help with this.
