Fail to download kernel symbols
Sysprogs forums › Forums › VisualKernel › Fail to download kernel symbols
  • #788
    I try Visual Kernel and want build a kernel module for the actual rasperry pi kernel 3.12.28+.
    But the Dialog “Installing kernel symbols” failed with:
    Unable to locate package linux-image-3.12.28+-dbg
    What can I do?
    The same was before with the headers, but that I solved with https://github.com/notro/rpi-source/wiki
    So the source is installed in the home folder.
    Can VisualKernel use this source?
    Peter
    #3065
    The Raspberry Pi distro does not include kernel debug packages, so if you want to develop/debug kernel modules for it, you need to build the kernel from source code. Follow this tutorial for more details: http://sysprogs.com/VisualKernel/tutorials/raspberry/basicmodule/
    #3064
    The code modul is small and well tested. So I need only to compile it and not debug.
    But the wizard can not finished without apply the kernel symbols?
    If I have to build the kernel from source code so I have to install a Debian VM first.
    #3062
    Yes, VisualKernel is focusing on seamless debugging experience, so configuring debugging is a mandatory step. If you just need to build your module, you can simply use the command line.
    #3063
    I have the actual debian debian-7.6.0-amd64 installed in a vm.
    At this step in the tuturial:
    peter@debian64:~/raspberry$ ${CCPREFIX}gcc -v
    /home/peter/raspberry/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf-gcc: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14′ not found (required by /home/peter/raspberry/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf-gcc)
    I get an error: `GLIBC_2.14′ not found.
    Installed is:
    ldd –version
    ldd (Debian EGLIBC 2.13-38+deb7u4) 2.13
    How can I get 2.14?
