Export data as CSV (Live Watch Plot)
Sysprogs forums Forums VisualGDB Export data as CSV (Live Watch Plot)
  • This topic has 2 replies, 2 voices, and was last updated 1 year ago by Lonka.
  • #35466
    Lonka
    When exporting Live Watch Plot data to CSV the data is saved to a file using comma as a seperator.
    The problem is that the floating point data also is saved using comma as a seperator (have a look at CSV_file.png)
    How do you change the settings of VisualGDB to express floating point using . instead of , (or change the seperator sign)?
    Best Regards Nikolaj T.L.
    #35473
    Thanks for reporting this. VisualGDB was indeed using a fixed “,” separator when generating CSV files.
    We have updated it to use the same system-level setting that Excel does, and also added a manual override option (Tools->Options->VisualGDB->General->Files->CSV file separator).
    Feel free to try this build: VisualGDB-6.0.101.5155.msi
    #35474
    Lonka
    Thank you very much I greatly appreciate your help.
    I have now tested the setup and it works
